Sealing scoop to carb
I am installing a aero scoop on my car wanted to know if i can use 3/16 aluminum plate or is it to heavy to mount directly to carb thanks.
That sounds heavier than necessary too me. On my injection engine i'm useing 1/16" tk., because that's the material i already have, but .040 would be tk. enough.
JMO Zip. |
The panel between my scoop and carb is .040 and works fine. JMO!
TS1955 |
I used 3/16 on my door car and then crushed the foam about 20% with the hood to get a good seal. I was afraid the lighter stuff would flex.
JMO Dave |
bonnett scoop
when i did my car i used a 14" aircleaner base and foam to seal carbie to bonnett worked real well
| All times are GMT -8. The time now is 11:48 AM. |
