-   -   Converting Camaro back to Rally Sport (https://www.racingjunk.com/forums/showthread.php?t=26780)
Harbone 12-22-2009 07:02 AM
my car was originally a Rally Sport so I bought the grille kit and started mocking her up...
original view
http://static.racingjunk.com/63/ui/9...475269-427.jpg
teardown
http://static.racingjunk.com/63/ui/2...475322-757.jpg
mockup
http://static.racingjunk.com/63/ui/5...475315-355.jpg
teadown again to install valance
http://static.racingjunk.com/63/ui/9...475329-807.jpg
valance installed now off to the bodyshop!
http://static.racingjunk.com/63/ui/4...475364-438.jpg
kwkracing 12-22-2009 05:39 PM
I would remove that fan, its a major air block at all speeds
Harbone 12-23-2009 05:14 AM
with a 498" big block, she needs all the air movement (artifically supplied) she can get! :D
kwkracing 12-23-2009 09:32 PM
Thats fine if you dont drive the car over 15 mph, the faster you go the less air you push throu a fan like that, it acts like a big 14" plate once your mph gets higher than the cfm the fan pulls on it own, air looks for the least restrictive path and goes over the car instead of threw the radiator. Just a lil tip incase u run into a problem later.
If it works, then thats awesome! Your car looks really nice! Good job.
Harbone 02-01-2010 11:07 AM
after a 2 weeks getting ready, 3 1/2 weeks at the bodyshop getting a lot more done than originally expected the bitch is back and all put together. All I have left to do is install the QA1 front coilover shock kit and new sway bar. Come on spring!!!!
http://static.racingjunk.com/63/ui/0...133930-280.jpg
http://static.racingjunk.com/63/ui/4...134154-864.jpg
TheYellaBrick 02-01-2010 03:44 PM
:shock: :shock: :D :D :D :D :D Pretty In RED !!
Tod74 02-01-2010 04:40 PM
:mrgreen: LOOKS GOOD!!!
cam67152 02-01-2010 08:15 PM
LOOKIN' REAL GOOD :!:
Did you do the rear as well?
X2 on SPRING :D
MEMRACING62 02-01-2010 08:17 PM
LOOKIN SWEEET...... 8)
BEAST477 02-02-2010 04:07 AM
Lookin' good harbone. I can't believe you want to get rid of it.
