Hilborn stack injection setup for SBC
just got an intake for my 360 chevy and need a recomendation for Nozzle size for Alcohol. the motor is 12.5 to 1, .590 lift roller cam, 6500 rpm redline, #0 pump 2-3/16 throat stacks. 2800lb? car with 4.56 gears, 33" tall tires, powerglide with 3200rpm stall. hoping to get 450-500 HP out of the motor
this is my first attemp at mechanical fuel injection and will take any advice available. Thanks guys Racerroo |
16AS would probable work best, but you coulds also run 14's or 18's. We run 18 AS but with a little larger size injection. Definately not smaller than 14AS.
JMO Zip. |
zipper did i readsomewhere you run 434's? any recomendation on jets?
thanks |
thanks With the "0" pump and 16 AS nozzles is .075, that will put you within .010 either way with a 360" motor. Set the High Speed lean out at 60 lbs on the leak down and if you have an idle bypass set it at 15 lbs. or less. Zip. |
Zip Thanks for the help.
| All times are GMT -8. The time now is 04:44 AM. |
