-   -   Radiator or not on my altered (https://www.racingjunk.com/forums/showthread.php?t=26643)
HitManSlingshot 12-10-2009 05:22 PM
Would like to know pros and cons of running a radiator on my altered thats going to run hilborn fuel injection on alky..
slowmotion 12-10-2009 06:12 PM
I wouldn't have a car without one. I just put a bigger radiator in my altered this year. What kind of racing are you planning on doing? Will you have time between rounds to cool a car with no radiator?
I assume you plan on towing the car around. I drive mine to staging, race and drive it back to the pits. My car also has an alternator. I don't have to charge between rounds.
When we put my car together, the idea was for the car to be as self-suficient as possible. I can load, unload and race by myself.
BTW I run pump gas. I know alky runs cooler.
THERATTLER 12-10-2009 06:25 PM
I have never had a rad on any of my alcohol dragsters , but as Dennis said , do you plan on driving to and back from the track??? my cars are towed to the lanes and then back to the trailer ..on an 1/8 mile pass the engine temp gets to around 180....it really depends on how you plan to use the car,,,JMO,,,Paul
zipper06 12-10-2009 06:51 PM
some factors to consider,#1 if you live in the south where the temp. gets up too a 100*, good plan, #2 you'll have run a belt drive pump, if you run a water pump on the front of the motor #3 if you plan on driving it to the lanes and back from the run, good plan and if you're running a 1/4 mile, good plan, because if you running brackets there's not enough time too cool down without a radiator.
kwkracing 12-10-2009 09:31 PM
Zipper, you forgot one.... You dont run a radiator when your heads have cracks in them.... lol
I have Ran my alky motors with and without cooling systems.
It depends on how u are using the car as already stated. My cars get towed and have plenty of time to cool down if they did ever get any heat in them.
zipper06 12-10-2009 11:48 PM
:) , i don't run water in my blown alcohol engine either, but then it's not run in a bracket situation
slowmotion 12-11-2009 05:53 AM
I use an electric proform on mine. Bolts in the stock location.
http://www.crossbonesmotorsports.com...ater-pump.html
I know where there is a Shogun remote water pump for sale. :roll:
suicidebomb 12-11-2009 05:58 AM
Meziere(spell), electric inline (remote)on mine, bolted to the frame. Ron Davis dragster radiator.Works like a champ.
