-   -   Question to all you hotdogs, Detroit locker or Limited slip (https://www.racingjunk.com/forums/showthread.php?t=26603)
zipper06 12-06-2009 10:45 PM
Some know i' building a Prostreet Sonoma. It's time to buy the rear end setup. I can buy a Detroit locker for less than $150.00 but i'm not sure this is the way to go. I't's my understanding that if you run a Detroit locker it doesn't lock up until the torque is applied, which means in a race situation the car would probably pull left or right off the starting line at the strip. Has anyone been there?
rabiddawg 12-07-2009 02:57 AM
you might also concider a detroit trutrac.
I got that in my camaro and it has nothing to wear out.
and hooks like a spool but takes corners like an open diff.
zipper06 12-07-2009 10:41 PM
Yes but i can buy a Detroit Locker for $120.00, on a budget i am SS. I haven't found a Posi for less than $400.00
rabiddawg 12-08-2009 02:33 AM
a locker for 120.00 should raise a few flags?????
TheRabbit 12-08-2009 04:49 AM
Years ago I had a Detroit Locker in a small truck that I drove everyday.
It worked great, but would sometimes pop like hell when you turned hard. That's normal for 'em but will scare the heck out of you till you get use to it. They are pricey, but worth it if you want ultimate hook up and street ability.
zipper06 12-08-2009 08:15 AM
I know where there is 3 of them, 2 for $120.00 and one for $199.00, the only problem is they are for the "H" case 3.250 carrier bearings.
rabiddawg 12-08-2009 03:48 PM
a few places I wouldnt get used parts
engine -tranny- rear end.
even at that price your gambling on it being good.
I would have someone look at it good before buying.
