fuel system design
Running a 351w with around 500hp. Trying to figure out a good place to start. Thinking 8an fuel line with 50gph fuel pump and 700cfm carb. Does this sound close? Should I run a pressure gauge or regulator?
Thanks |
Re: fuel system design
Thanks |
Thanks TS1955 |
Actually jegs sells a 'generic' electric pump kit which is probably just a Holley blue or black in diguise anyway.
I bought one for the boys mustang (351W), regulator even had the holley insignia on it. Run # 8 line to the engine bay and set the regulator @ 6.5 to 7 psi and your good to go. I'd go with a 750 cfm carb though. JMO> Cp |
carb sized
i definitely agree with cepx11 on upping the carb size to 750
| All times are GMT -8. The time now is 12:29 AM. |
