-   GM LS engine talk (https://www.racingjunk.com/forums/forumdisplay.php?f=21)
-   -   1994 camaro (https://www.racingjunk.com/forums/showthread.php?t=26530)
stormi878 12-01-2009 04:30 AM
1994 camaro
I have a 1978 chevy 383 stroker built from ground up 520 lift cam soild lifter alum heads looking to remove the 5.7efi from a 1994 camaro and use all of the efi stuff on the stroker engine what kind of trouble will i have or can it be done
skipjobe 07-27-2010 09:06 PM
You will have to get in to the computer and delete the o2 sensors or install them, delete ac, move up rev limiter, disable EGR, disable AIR, disable CCP codes disable Vats disable Electronic automatic transmission codes, pull timing for nitrous or boost , adjust for injector size. MadZ28.com can get you a start up tune. Good luck
skipjobe 07-27-2010 09:23 PM
You will have to tune with a laptop.
k9605ocsd 03-31-2012 08:29 AM
Lt1 engine build up
Im from Indiana and we just built our 383 stroker motor, we need to have the computer upgraded for the changes that we made, anyone know where I can get a computer program of where we can take it it get it reprogrammed
skipjobe1 07-29-2012 04:18 PM
1994
I had mad z28 program my pc for a 383 he hit almost dead on the money, you fill out a data sheet with all your specs cam lift head flow injectors size, I turned 12.30s on his mail order tune.
