Th400 or Poweglide ?
I've been going round for round on this decision as my research so far has not convinced me to lean in either direction. Are there any experienced builders or racers out there that can offer some first hand knowledge about this topic? Most comparisons I see ask about car weight and HP/Torque. This is a pro-street car that is driven short distances on occassion for car cruises, etc (approx. 300mi/yr). Here is the relavant information about my car.
68 Firebird 3300 lbs w/driver 474 stroker Pontiac 742 crank HP & 672 ftlb torque Th350 trans w/4500 stall - NO Trans-Brake 3.73 rear gear 28" x 10" slick Currently runs 9.90s at 136mph....1.42 @ 60' I want to change the Th350 because I intend to start using Nitrous, which will put me at about 1000HP total (more than I want to trust my TH350 to handle), and I would like to install a trans-brake. Thanks, Bob |
400
You wont catch me saying this too often, but for your app, TH400
glide or 400
x3
What is an X3 ?
Need more input please
Thanks for your feedback, but can you explain why you would pick the Th400 over the glide for my application?
Thanks |
3 gears forward as opposed to 2 gears forward...better for street use even if only occasionally.
also a stock powerglide case wont be as strong. funner to drive th400...my vote and heart is with the turbo 400!!!
400 Turbo also with the NOS you will kill that 350.
I ran a TH400 in my Camaro. It was race built but I did manage to f*&k it with around 1000hp.
I was using a transbrake and 3800 stall converter. It would be better than a glide for your application but don't go doing burnouts starting in 1st gear. |
| All times are GMT -8. The time now is 09:26 PM. |
