-   -   scammer in maple hieghts oh doubleOHman (https://www.racingjunk.com/forums/showthread.php?t=26464)
garys67 11-24-2009 05:08 PM
ad 1717362 was totall junk ..he would not return.my call
MEMRACING62 11-24-2009 05:30 PM
Re: scammer in maple hieghts oh doubleOHman
stamped. did you buy this??? what makes this a scam??
bjuice 11-24-2009 05:44 PM
I found this AD Posted by GARYS67.
http://www.racingjunk.com/category/9...eights-oh.html
Ad #1724217 Posted:2009-11-24 20:13:10
This ad expires in 83 days.
WARNING liar and scammer in maple heights oh
DOUBLEOHMAN would not even return my call .
HIS AD READ 357cid sbc fresh...and then went on to say it has a steal crank,steal rods,202 valves new pistons,nice motor never been fired since rebuild..said it ran 11.60s in his nova ,,that motor wouldnt run 15.60 if it would have been a good motor...it turned out to have 1.5 gals of water in oil pan,,,stock crank ,stock rods 1.94 valves,and a groove in the cil .wall so bad you couldnt get it out boring it to 120 over!! block was junk.heads were also junk .valves sunk,mixed match springs ,two bolt bosses were broke ...so dont deal w/ this guy ....jeramia its monkeys like you that give this sight a bad rap ..your day is coming
Seller Phone Number: 217-825-8943
This item is NEW
Trades NOT ACCEPTED
Item Location: PANA, IL Get Directions To This City
Instructions for buyer: liar
MEMRACING62 11-24-2009 05:56 PM
sent him a message ,lets here the other side.
garys67 11-24-2009 06:08 PM
yes i did buy this ..drove 9 hrs one way..motor had 1.5 gals of water in the oil pan,,it had a stock crank and rods not steal like th ad said...it had a groove in the cylinder wall that could not be fixed..he said it had 202 valves but it was 194 s...the heads had two bolt bosses broke,mix match springs some z springs some stock ,some valves were sunk..he sent 15 rocker arms..the truth is the cam and lifters were good..even though it wasnt a crane cam it was a 530 [email protected]y thing else was junk ..i called and let messages and he would not return my call
THERATTLER 11-24-2009 07:02 PM
ad states he will pull heads to show fresh parts , I take it that you didn't take advantage of this...thats a mighty long drive for a $600 engine??? :?
DirkaDirka 11-24-2009 07:58 PM
Do you have pics of the parts and block?? That will help better your case with us.
mopar1968 11-24-2009 08:44 PM
I agree with ''Dirka'' we need to see this :!: :!:
''JUST MY TWO CENT'S WORTH''
