-   -   timing (https://www.racingjunk.com/forums/showthread.php?t=26428)
supersmurf666 11-20-2009 06:58 PM
timing
ive got a 355 sbc w/10.5 cr,202 ported heads,305h cam,holley 750 d.p. and a strip dominator intake in a 69 chevy truck.where should the timing be???
kwkracing 11-20-2009 08:17 PM
36-38-40 degrees total timing
cepx111 11-20-2009 10:09 PM
Some combos like more (38-40) some like less (34-36)
It's a guessing game really, the only way to know for sure is have it on a dyno and play with it untill you get peak performance.
Middle of the road is about 35 and a good starting point.
Make a few passes going up and down a couple degrees and compare notes.
Goodluck, Cp
supersmurf666 11-20-2009 10:18 PM
timing
thanks for the info.
bjuice 11-22-2009 06:06 AM
charles is Right...but if you have no access to dyno...test and tune the car...normally Higher Timing is gonna be more bottom end and less top end...same with valve lash...a tight lash will have more bottom end, looser lash top end.
in the past i would just keep inching it up until the 60 ft slowed down noticably or..keep in mind don't be fooled by Tire spin..you should be able to feel the diffference in the seat your seat....you can always feel that certain vibration when she is running crisp...
I personally would start out with 36 and work up toward the 40 mark and see how it feels
