-   -   big block chevy knocking when cold (https://www.racingjunk.com/forums/showthread.php?t=26417)
j0694 11-19-2009 07:07 PM
i have a big block chevy that has a pretty noticable knock when it is cold started then goes away once heat is built up. any suggestions on what is causing this
TheYellaBrick 11-19-2009 07:31 PM
How many miles on this engine?
Sounds like a case of major case of piston slap....
cepx111 11-19-2009 08:54 PM
Huh DD?
Case of beer maybe....lol
Is the knocking noise down low or towards the top?
What is the oil pressure? > hot?
Usually a rod or bearing noise will get worse when hot.
They way you described it, it kinda sounds like a lifter taking it's sweet time priming up.
A piston slap will sound similar, after a few minutes of driving they'll heat up and expand which quietens them down, either problem is no biggie, drive it till the wheels fall off I say.
What type of oil filter you using?
El~ cheapo filters like a "FRAM" the anti drain back valve never works, try a wix, napa brand or purolater.
The 'good' filters will hold some residual pressure and stay full after you shut the motor off - when you start it up (cold) the motor wont do all that klinking and clattering till the oil pressure builds up.
Something to think about.
Goodluck, Cp
fla1976 11-20-2009 01:37 AM
Sounds like piston slap to me also. Are the pistons forged?
TheYellaBrick 11-20-2009 05:45 AM
Huh DD?
:oops: :oops: :oops: a FULL case of re-re-repeat , It's the pain meds, I swear it ! :roll: :shock: :shock:
j0694 11-20-2009 10:22 AM
thanks for the input guys
it has forged pistons and oil pressure when hot is around 40 psi idling at around 1200 rpm
it doesnt sound like a rod knocking to me though
fla1976 11-20-2009 12:25 PM
Here is some info on piston slap:
http://www.pistonslap.com/whatisit.htm
mopar1968 11-20-2009 06:15 PM
Probably Wrist pin knock :!: :!: But then again it is a Chebby :!: :lol: :lol: [Just kidding]
''JUST MY TWO CENT'S WORTH''
Scooterz 11-23-2009 03:41 PM
I have heard solid lifters do this when cold... then go away when warm... do you have solid lifters??
kwkracing 11-23-2009 05:08 PM
I have a street driven engine thats a little loose on the crank, When its cold outside it knocks about 3-4 times when it first starts up.... i use to worry about it, but after it got 75,000 miles i quit.
