-   -   best way to determine a rear end gear ratio (https://www.racingjunk.com/forums/showthread.php?t=26413)
chevyart 11-19-2009 04:23 PM
what is the formula for determining a rear end ratio. my buddies vega has 26 inch tires,4 speed muncie, and a 355 sbc. he says the cam is a circle track cam and makes power from 3500-about 8000 rpms, say he wanteed to be coming through the traps at about 7800 rpms, what would be the aprox ratio to obtain the desired rpm do i have enough specs to complete the formula thanks chevy art
zipper06 11-19-2009 08:41 PM
You can use this formula EX: if the engine has enough HP to run 120 mph in the qtr.
The gear ratio would be a 5.00 gear. But i'm thinking 4.88's or 4.86 gear would work best. Ofcourse if the HP is higher you'll need to go down on the gear.
http://www.wallaceracing.com/calcrgr.php
MEMRACING62 11-20-2009 03:43 AM
try this http://richmondgear.com/01calculators.html
