-   -   header evac (https://www.racingjunk.com/forums/showthread.php?t=26387)
hvychvy 11-17-2009 04:06 AM
header evac
I have a 1983 s-10 w/ 383sbc, iron heads "nuthin fancy" just a weekend toy. I have purchased the moroso header evac kit and I need to know how far from the collector this pipe inserts should be installed. I am using the hedman s-10 shorty headers with a 3" extension coming down and turning out under the door, this is a race only setup. I appreciate any help, thanks in advance.
cepx111 11-17-2009 11:26 PM
Generally you put them within 2 or 3 inches of the header flange inside the collector.
I'd say either right before the ninety degree bend or right after it where the collector is straight.
hvychvy 11-18-2009 04:07 AM
Thanks, that's what I thought just wasn't sure, so I came to the RJ braintrust.
mytmouz 11-18-2009 04:56 AM
If you have the shorties, I think you will need to put them in the pipe further downstream, after it makes the turn from the firewall should be fine...
hvychvy 11-19-2009 05:21 AM
Thanks guys I got the kit yesterday and I'm going to put them in tonight.
