12.00 302 combos
hey i have a 1993 Ford Ranger with 93 Mustang Cobra Engine wit Performer RPM Intake, Holley 750 DP,3.73 Gears,TCI Street Fighter C-4 wit Reverse Valve Job,275/60-15 Hoosier Drag Radials
my fastest time is a 13.40 on just motor... i'm trying to figure out wat mods i can do to get into some low 12s on motor. i've recently put a 125 power shot on it nd from wat i've found it should run an estimated 12.40 to 12.10 on spray. thats jus not fast enough for me...NEED HELP!!! THANKS FOR ANY POSTS |
What cam are you running?? Also do you have headers on it?? What other upgrades to the engine do you have on it? Whats the compression ratio at?
the stock 93 cobra cam i wanna say a b-303 or e-303 cam, stock compression, it has headers but there the smallest ones to make the fit work with the steering shaft.
Definetly need a upgrade in the cam/head department.
What type of ignition you running? A MSD box will help a bunch. How is traction off the line? Any slippage or stumble off the line will kill your ET's. What is your best sixty foot time. Cp |
6A MSD,MSD blaster coil, VERY GOOD traction on motor spins less then a half a car, i think the converter is a problem too it stall up to about 3500-3700RPM and i think the gt-40 setup powerband range is from 2000-5500RPM by stalling at 3500RPM takes away alot of low end power i think...shift points are 5600 going to second nd 5700 going to third... was at a shitty track they didn't give out short times or mph...THAT SUCKS!!!
| All times are GMT -8. The time now is 07:18 PM. |
