dam pooch
ok folks turnin to you for help i have a 396 30over 10.25 compression in a 2700 lb car with a 4500 converter and a glide with a 586 gear car runs on e85 runs ok starts good crack the throttle and its there take it to the track put it under a load and wata pooch just wont rpm at all throw me some ideas here or email [email protected]
what msd box and coil ?
pooch
6al box (chip removed) msd coil msd distributor timing at 40 locked out
Is this combo new or have you ran it before?
TS1955 |
pooch
came on the car when i got it but all seems to work ok
you said runs on e85,,,what kind of induction?
pooch
800 cfm converted carb strip dominator intake
sorry , don't know alot about carbs , on injection when mine won't rpm , it is usually a little fat on the fuel mixture,,,mayby somebody else has a little experiance with the e85 carbs
When you say it wont 'RPM' are you refering to a stall or a bog off the line.
Any popping or mis-firing? Are you getting full throttle? How about the spark plugs, are they new or old? What are they gapped at? More info please. |
CHECK AND MAKE SURE THE CARB IS OPENING ALL THE WAY WHEN YOU FLOOR IT.
| All times are GMT -8. The time now is 09:28 PM. |
