Powerglide Parts
Hey guys, needing some PG parts for a buddies trans, was going to order from TSR but told him i'd ask around and see what I could come up with.
1- Clutch Hub Lightened 1- Gasket and Seal Kit 8 -Alto Red .060 Frictions 6- Reverse .098 Frictions Alto Red 6- Reverse Steels .070 8- High Steels .060 1-PG Filter 1- PG Pump seal 1- Case Saver 1- Shorty Cover Seal ( standard extension housing seal used in a long trans) you can email or pm me [email protected] thanks guys |
P.M Sent.
back at ya :D
Dave,
Call Dion and see what he has 330-584-3679 |
I did have a bearing kit that changed the older shorty housing that had a bushing over to a bearing type..if you can use it ,I will see if i can find it and send it to you ,,i have no use for it....Paul
| All times are GMT -8. The time now is 07:44 AM. |
