-   -   565ci bbc tunnel ram carbs pump gas best choice? (https://www.racingjunk.com/forums/showthread.php?t=26007)
delete 10-12-2009 07:36 AM
thanks alot any exsperience or helpful advise.
-i want to run a twin carb set up on a tunnel ram with regular pump gas on a 565ci bbc engine with 5 speed trans manual and solid roller cam aggresive radical cam.this is for street driving and quarter mile race maybe once a month.
- i was thinking twin 750 range carbs?
bjuice 10-12-2009 01:57 PM
what do u mean by "Regular Pump "?
delete 10-12-2009 05:05 PM
pump gas
pump gas
BEAST477 10-12-2009 05:12 PM
Would that be 87 or 93 octane or E85 ??? :roll:
delete 10-13-2009 07:33 AM
93 octane pump gas street fuel
bjuice 10-17-2009 09:49 AM
Big difference between 87/93 octane and E-85........You will be able to run more compression and a little more radical cam with E-85..you will also need the carbs blueprinted for e-85 and the Fuel pump E-85 Compatiable.
E-85 is around 105 Octane. 8)
what area do you live in ?
russ67chevelle 10-17-2009 05:33 PM
only tunnel ram id use on a motor that big is a fabbed one(big dollars)if i was u id look at dart or super vic with a SINGLE 1150 or 1050 minimum cfm....
if u want a motor that goes build with performance parts,if u want a bling bling motor,then go with the old school two fours
LuckyDawgRacing 10-23-2009 08:36 AM
and if its a dart Id port it
