-   -   BBC horsepower help . (https://www.racingjunk.com/forums/showthread.php?t=26003)
whosyurdaddy 10-11-2009 02:16 PM
Guys, I've got a chance to buy a 454 with a 30 over bore and oval port heads . The motor was machined several years ago and never run , it has been sealed and stored in a climate controlled building until about a year ago and is not sitting in the owners personal garage . The motor has stock crank , new unknown flat top pistons and I'm assuming stock rods .
Now I'm not a motor person so can you guys tell what it would take to make this a 600-650hp motor . Just in case anyone is wondering I can buy this motor for $1200 . Thanks
fla1976 10-11-2009 02:44 PM
454
There are at least six 454 engines in the classifieds that are between $500 and $1250, one is a 1970 HP. So I'd say you might find a better deal. Ads: 1676263, 1678659, 1673872, 1673482, 1672845, and 1670876. I'm sure there are others. Maybe there is one near you.
whosyurdaddy 10-11-2009 04:59 PM
Thanks for the heads up on the other motors but I still would like to know what it takes to build 600-650hp 454 ? Thanks
bbchevy 10-11-2009 05:03 PM
HP
About 3500 to 4000.00 $.Give or take a NICKLE or 2?
Later
G 8)
hammertime 10-11-2009 05:25 PM
if buying new 4000 if buying used far less ...
454 11:1 comp, 675/700 lift roller cam and even pro comp heads, with a 4150 950 gas carb would for sure get it there ..
Tod74 10-11-2009 07:23 PM
$600
http://www.jegs.com/p/NOS/NOS-Big-Sh...49116/10002/-1
signsbyesa 10-11-2009 08:20 PM
a corvette motor would get you there quicker :wink:
Tod74 10-11-2009 08:39 PM
If he were going to get a corvette motor then a 350 would suffice for a measly 600 HP
