-   -   Better MPG outta my truck suggestions? (https://www.racingjunk.com/forums/showthread.php?t=25991)
Aarons81step 10-10-2009 07:49 AM
I have a 1981 chevy stepside 2wheel drive it has a 350 bone stock except for and edelbrock 650 carb i jetted the carb way down but i still only get about 16mpg any suggestions?
MEMRACING62 10-10-2009 02:19 PM
16 mpg out of that truck!! I would say your hard to please :lol: had 80 4x4 8- 10 is all that truck would ever get.
itsabird 10-10-2009 02:29 PM
wow!! i would settle for that out of my old heap, you are bragging right. :)
altailites 10-10-2009 09:09 PM
Re: Better MPG outta my truck suggestions?
drive it off a cliff for better mpg :P and I call BS on 16mpg my dammmm 06 duramax only gets 15mpg
kwkracing 10-10-2009 10:10 PM
Well i guess you missed cash for clunkers....jk!
Maybe you could put a carb like this on it. LOL
http://img12.imageshack.us/img12/4027/carbcarteryf.jpg
dak697 10-13-2009 10:52 AM
I had a 2whl drive blazer, 350 + 373 gears. I built a motor for it stock heads, quadajet carb and a 260 comp cam. Milage was not as good as 16 but I think it was pretty close. It would tow my buddies ski boat great.
My buddie with the boat had an older blazer that we put together the same motor trany package except it had an aluminum intake,Edelbrock carb that was recommended for the motor/intake, the same 260 comp grind and 3.08 gears
He drove to Palm springs with the boat behind him and got close to 16.. but he was going 70... Tried to keep the motor around 2000RPM max
To get milage on the highway. Drive the speed limit and use the cruise. My 2007 F150 gets decent milage if I do that.
Scooterz 10-17-2009 08:34 AM
???????????? 16 MPG on a SBC in a step-side????? Heres mine: I have a 1975 Chevy 4X4 w/ a 350 bone stock except for headers, edlebrock int/carb. It has 97,000 miles & has a 4SPEED..... this truck is a lifted step-side....
On a good day, it gets 10 miles to the gallon. On a bad day, it gets 10 miles a gallon. When I stuff my foot onto it all the time, it gets 10 miles to the gallon. When I go up hill & down the hill, it gets 10 miles to the gallon. I am pretty sure if any one of you drove it, it would get about 10 miles to the gallon.
cepx111 10-19-2009 02:03 PM
16MPG is not bad for a full size chevy truck, they are nortious for getting crappy gas milage anyway.
A high flow cotton air filter like a K/N, 2 barrel carb & highway gears would be my first thought.
Keep your tires aired up to the MAX setting, always.
Do you have a overdrive trans? If not put one in.
Snythetic oil in the engine, trans and rearend is worth a few.
I'd also stick a giant vacuum gauge on the dash and drive to maintain the higest vacuum at all times.
Goodluck, Cp
TheYellaBrick 10-19-2009 02:54 PM
Install a Briggs and Stratton V2........and leave way early !! :D :D :D
itsabird 10-19-2009 04:29 PM
yep :D :D
