Carb info for dragster
Lookin for some info, I'm new at racing a dragster, heres my dilema; I have a 358 with a .530 lift hydraulic cam, double hump 2.02 heads, victor Jr intake w/super sucker spacer. What Carb do I need that wont bog? any info on Demons, never had one?
Need a ton of more info;
- ALL the cam specs - Compression ratio - What has been done to the heads - How old is the engine as it is now - Trans specs - Rear gear ratio - Weight of car wet - Rear tire diameter - and anything else you can give us |
Holley HP 750 dp
cam specs are 244/254 @.050 .510/.530 lift hydraulic flat tappet, range 3500-7000 rpm. Flat top pistons 64cc chamber heads 2.02/1.60 valves stock runners, straight plug double hump no acc. holes, engine is fresh. 4:10 rear, 33" tire, power glide with brake, 5500 stahl, car maybe 1400lbs
I am picking up a 750HP DP
Thanks |
| All times are GMT -8. The time now is 09:19 PM. |
