-   -   blown bbc ring and bearing question (https://www.racingjunk.com/forums/showthread.php?t=25877)
taps 09-29-2009 08:10 AM
i am about to assemble short block.4.5 bore 4.0 stroke dart block bbc.871 blown on race gas,i was going to use totalseal ts1 gaples rings and clevite h series bearings do you think this is a good choice or do you have other suggestions.also i believe the second ring is gapless what should i set the top ring end gap at?
zipper06 09-29-2009 08:48 AM
Total seal makes a blower/nitrous ring set, might be a better choice than the TS1 set. H style bearing good choice, just make sure you put some clearance in them, I run .0025/.003 with steel tods and up to .0035 with alum rods, with 20/50 oil.
OneBadGMC 09-29-2009 09:06 AM
http://www.totalseal.com/TechPage.as...plessPistRings
Since you're running a standard bore size, if it's not a street car or very little street car use (10%) run a dykes top ring and standard second.
If the pistons are gas ported, you can get away with their AP set.
Personally, I wouldn't run a gapless set with a blower. You would be well advised to call Total Seal and talk to them about what you are doing. They have VERY good tech people that will help you pick the correct ring for your application.
And I concur with Zip on the rod clearances, plus I run .0035 on the mains.
Brad Penn, Valvoline ZR1, or Joe Gibbs oil only for blower motors. We gotta have the good stuff. Don't run synthetics when breaking the motor in.
kwkracing 09-29-2009 12:59 PM
Why do you say no the gapless ring, since they do have a gap they just over lap, or atleast mine do. my blown bbc alky, i took two sets of z gap rings and run them top and middle. Have not had any problems i that i know of?
OneBadGMC 09-29-2009 03:11 PM
Total Seal advised me against it. :?
kwkracing 09-29-2009 05:24 PM
Any reasoning??? maybe the extreme heat and pressure keep the ring from being able to collapse a few when the cylinder gets tight being the ring overlaps??? It would make good sense..
OneBadGMC 09-29-2009 07:00 PM
No idea.
They and I both wanted to run a Dykes top ring, but unfortunately they didn't make one in my bore size 4.614.
So, the next best choice was to gas port the piston and run the AP rings.
ARUSSELL 09-30-2009 10:28 AM
I would say stay with a conventional 1/16 ring, hellfire top.
jed5161 10-05-2009 12:24 PM
from what i understand. gapless rings will "fludder". especially the middle ring due to pressure getting caught in between it and the top ring.
