-   -   ? ABOUT SLICKS (https://www.racingjunk.com/forums/showthread.php?t=25874)
JEFF69Z28 09-29-2009 07:21 AM
? ABOUT SLICKS
SHOULD I RUN TUBES OR NOT?
kod99 09-29-2009 08:53 PM
I don't run tubes in my slicks. I don't see any advantage to running tubes. IMO.
curtisreed 09-30-2009 04:16 AM
I don't run slicks but adding them is like going to a stiffer wall tire. They also add weight, although not a lot. Are you having trouble with holding air or ?????
Curtis
fla1976 09-30-2009 12:39 PM
Tubes
If you can run without the tubes, I would. It's just extra rotating mass. If you coat the inside of the slicks with Ivory soap when you mount them, it will seal the tire and allow it to be run tubeless.
THERATTLER 09-30-2009 01:04 PM
M/T slicks are sold as a tube type tire , in their adds they state that
these tires require tubes , of course they also sell tubes for $50.00 bucks a pop too...I have seen plenty of people run them tubeless with the dish washing soap trick...
