turbo 400 built by harry tillman of aston pa.
I BOUGHT THIS TRANSMISION FROM HARRY TILLMANS IN ASTON PA, WENT AROUND THE BLOCK 1 TIME WITH THIS TRANSMISION , WHEN I TOOK IT TO THE TRACK , I SHIFTED FROM FIRST TO SECOND IN THE BURNOUT THE TRANSMISION EXPLODED, THIS WAS STREET CAR THAT THIS TRANS WAS IN , WHEN IN ALL REALITY THIS WAS TRANS WAS BUILT FOR A HIGH HORSEPOWER CAR , WHICH COST $1375.00 , REASON FOR EXPLOSION: WE TOOK THE TRANS TO 2 OTHER TRANSMISSION SHOPS TO FIND OUT WHAT HAPPENED AND THEY TOLD US THAT THE HIGH GEAR DRUM HAD A CRACK IN IT IN WHICH THE BUILDER DID NOT SEE. THIS TRANS BENT THE DRIVESHAFT IN A U SHAPE , TOOK THE FLOOR OUT , AND TOOK A CORNER OF THE ENGINE BLOCK OFF. WHEN WE WENT HARRY HE WOULDNT DO NOTHING FOR ME. THANKS HARRY TILLMAN SPEED SHOP OF ASTON PA. [/code][/url]
Re: turbo 400 built by harry tillman of aston pa.
When the 1-2 shift occurs in a non-loaded condition, such as a burnout, the low roller sprag can over speed and fail, causing a catastrophic failure like the one you encountered. The same failure can happen if there is a driveshaft or rear end failure at any point when power is being applied. The same failure can occur when you shift into neutral at the top end of the track. If the drum failed, how would they know it was cracked prior? How do you know the low roller sprag didn't fail when you did an improper burnout? |
If you went around the block or ran it on jack stands with everything working, then it is very easy for this guy to stop and say that it was improper use that created this problem. Hard to say the guy scammed you. I think you just learned an expensive lesson.
Yup,.......... Shift = Kapowie!,,I you are shifting in a burnout,unfortunately,weather it was his fault or yours,you were indeed at fault.... just my .02 ,shared from experience....
1375.00 Gee most racing powerglides w/needle bearings cost 35 to 3800.00 bucks... sounds cheap for a turb400!!!
I think what we have here is probably (as stated before) an expensive learning lesson about how not to do a burnout. |
I know this is the Feedback & Scammer section, but I want to say thanks to onebadGMC for the info. I have never had a high HP car before now and never knew not to use first gear for a burnout. I have always used it in lesser HP cars. Thanks again for the info you probably saved me some headache and money.
Originally Posted by fbodyjunkie
I know this is the scammer section, but I want to say thanks to onebadGMC for the info. I have never had a high HP car before now and never knew not to use first gear for a burnout. I have always used it in lesser HP cars. Thanks again for the info you probably saved me some headache and money.
for some reason the word scammer always overshadows the Feedback Part..... :wink: originally it was posted in the general comments section and i moved it to it's proper place |
My bad Bjuice, I was just making it the shorter of the 2. Sorry about that. I fixed my boo-boo.
| All times are GMT -8. The time now is 10:04 AM. |
