-   -   Coil Over Shock Advantage (https://www.racingjunk.com/forums/showthread.php?t=25789)
jreiley 09-22-2009 01:35 PM
If a car already has coil springs and shocks on the front end, is their any advantage to runing a coil-over system. Drag car only.
bjuice 09-23-2009 11:58 AM
yes...you can adjust Rideheight and monkey with wheel weights with Coil overs...factory Coil springs with Shocks are not the same.
DO some homework on Coil over shocks.."Google" and it will answer alot of your questions
