New to Electronics
Hello,
I am new to electronics, and need some help. I am getting a dragster and need to get a box, throttle stop (preferably w/ starting line enhancer) and the works to go with it. What are you opinions on the best units and what all do I need to buy to get started? Thanks! |
In a dragster, I'd recommend either a Dedenbear Lightning or K&R Procube due to their size and the limited space you'll have. I'm a Dedenbear guy myself. K&R, Biondo, and others have dual cyl co2 stops that work very well. You can set one cyl for starting line enhancer and the other for et control........
I have a Biondo 85 in my car. It's a delay box with crossover and has a 4 stage throttle-stop timer and has the starting line enhancer.
TS1955 |
I like the biondo stuff its very easy to wire and use.
The next thing I will say, a baseplate stop is easier to 90 race with then a linkage style, they are more predicatable. But if you do go linkage make sure you buy a actual ts and not just a SLE |
My personal preference is Biondo Elite 500 box with a dedenbear under the carb electric stop that has the primary kit. This setup works good whether you are killing a few tenths or a couple seconds to get to a 90.
a linkage stop will work, but is nowhere near as consistent. Look around at the winners and you generally wont see a linkage deal. The starting line enhancer is awesome when bracket racing a fast car, but its no use on pro tree racing. |
| All times are GMT -8. The time now is 04:13 AM. |
