-   -   how do you wire in a netural saftey switch (https://www.racingjunk.com/forums/showthread.php?t=25781)
greenone60 09-21-2009 05:24 PM
i have a hurst quarter stick shifter and i need to wire in a saftey switch the switch is allready in the shifter? thanks
fla1976 09-22-2009 12:21 AM
Switch
The switch is placed between wire that runs from the ignition switch to the starter solenoid.
TS1955 09-22-2009 03:31 AM
You actually want it between the starter button and the solenoid. Not the ignition switch!
TS1955
oldandtired 09-22-2009 12:50 PM
TS1955
If the micro switch will carry the amperage. Dave
fla1976 09-22-2009 12:59 PM
Switch
He never stated that he was using a push button, so I told him the basic hook up so he could adapt it to his own use.
TS1955 09-22-2009 01:07 PM
TS1955
Dave, you are correct, but it still needs to be wired in the "start" circuit not the ignition circuit. That was what I was pointing out.
TS1955
greenone60 09-23-2009 02:51 PM
thanks guys,wired in switch today and works fine getting ready for the united outlaw series coming here to huntsville alabama the first week of oct.
