TH350 AND BBC
Will a th350 bolt up to a bbc?
350
If it has the Chevrolet bolt pattern.
There were TH350s in Buick, Olds and Pontiac., but the bolt pattern is different. If it was behind a small block Chevy it will fit the BBC. |
That's good to hear. It was on a sbc. Save's me some bucks, for awhile.
I'd be looking for a TH400 in the meantime.
TH350
X2 on the 400.
will the bop th350 trans also fit the chevy engine?
Go back & read the 2nd post! :shock:
http://www.compperformancegroupstore...ct_Code=230000 Cp |
I'd go with a TH400 or a powerglide depending on application. Cp |
My Trans builder here in Oregon (he is a bracket racer) told me that a good built TH350 is only acceptable to about 450HP. He will not build one if the application is over that. TH400 is the way to go.
| All times are GMT -8. The time now is 11:10 AM. |
