WHAT OIL TO USE
WHAT TYPE OF OIL DOES EVERYONE USE.DOES IT HAVE TO BE STRAIGHT WEIGHT OR CAN I USE 10W30 FOR MY RACE CAR VERSES 15W40, IM CONFUSED ABOUT THIS.
MAINLY OIL WEIGHTS ARE DEPENDANT ON HOW MUCH BEARING CLEARANCE U HAVE IN RODS AND MAINS...IF IT IS A STOCK REBUILD WITH STOCK CLEARANCES,USE STOCK RECOMMENDED WEIGHT OIL.IF IT IS A LOOSE MOTOR SET UP FOR RACING USE THICKER OIL LIKE 20/50
BRAD PENN IS KNOWN FOR ITS SLIPPERYNESS WHEN CONTAMINATED WITH GASOLINE(GREAT NEWS FOR NITROUS USERS) |
I used to use 10w/30 but it was so thin my dry sump pump was leaking around the front seal.
I now use 25w/50 race oil. Some say I'll lose a little hp but I don't seem to. |
10w30 full syn pennsoil
20/50 is a safe option, you do give up a few hp
15/40 ROTELLA
X2 on the rotela T 15/40,
15/40 schaeffers synthetic
I've ran 4 different oils this year, on alky injection with a primer plus
15/40 shell stuff looked good going in .. didnt look so hot coming out 20/50 & 10/30 vr1 -- little to no difference other then 5 hundreths on the track and whats in there now is 5w/40 syn castrol, a buddy of mine did some r&d on this stuff, and oil temp is very good under hard use. So far so good. |
10w30 Mobile 1 or Valvoline full synthetic.....
| All times are GMT -8. The time now is 02:08 AM. |
