-   -   oil in water (https://www.racingjunk.com/forums/showthread.php?t=25696)
carhunter1967 09-14-2009 04:21 PM
oil in water
have water in one cyl. worst case what am i looking at thanks
DirkaDirka 09-14-2009 04:25 PM
Blown head gasket, cracked head, cracked block
kwkracing 09-14-2009 04:51 PM
Bent rod, cracked cylinder.....
bjuice 09-14-2009 04:56 PM
you might want to change your Focus on looking for the cheapest thing..
leaking intake ?... :D
TheYellaBrick 09-14-2009 04:58 PM
No matter what, ya gotta yank the intake and the head anyway to get a looksee....
jaxsmith 09-14-2009 06:02 PM
If the motor did not quit spinning due to the water try a can of K&W Block seal. Follow the directions on the can to the "t". I have seen miracles with this stuff. We all get in situations where we need it to last a little longer and this will do it.
cepx111 09-14-2009 08:28 PM
I agree with Brian dont get to ahead of your self.
I had a similar occurence , water in the oil - I was dead set it was a blown head gasket(s) at minimum.
I had all my tools out ready to yank both heads and the cherry picker handy, just in case.
I slowed down after pulling the intake and did a close visual inspection on the gaskets.
Whollah! found one gasket that had been leaking. What a relief.
Luckily I didnt get to carried away as I didnt have either header off, nor the V/C's.
Point is a: It's never a bad idea to be prepared for a worst case senario, but then agian, dont fix what aint broke either.
JMO>Cp
carhunter1967 09-15-2009 04:25 AM
thanks for all the replys put in the shop tare it down inspect for the worse
