-   -   powerglide no reverse(rossler trans with brake) (https://www.racingjunk.com/forums/showthread.php?t=25649)
promod62 09-10-2009 09:52 AM
fresh trans but has been on shelf for years, apears to have only have high?? gear no reverse or low, wont back up even holding trans brake button, what should i ck?? Thank,s Tim
shawnp 09-10-2009 02:21 PM
I would call Carl 1st. If you open it, then you are going to void any help you might get from him (and good luck with that). If I wanted to get it fixed right, then I would use the only trans guys in NE Ohio in either Dion Vickers or Marco Aburzzi.
promod62 09-14-2009 10:40 AM
trans
i did call him he was nice, said to send valve body back, i did, but couldnt wait i installed a tci v-body i had here out of another trans and works good now, thank,s
