powerglide, WILL NOT SHIFT out of low!
Trans worked fine the the last two passes I made I had to let off, because the trans wouldnt shift out of low gear! electric shifter is shifting into 2nd but the trans is not, you can move the shifter back and forth from low to high and it wont shift out of low gear! it shift into rev. park, neutral and low, but will not go into high!
Sounds to me that there is something broke inside the tranny that is preventing it from shifting from low to high gear. IMO
Check your shifter adjustment. Pull the cable off the lever in ever gear .
I had one do that a couple years back in a hardtail dragster. It broke the high gear drum. Everything worked except drive. It broke the drum when it bit on the burnout. Hope this helps...
| All times are GMT -8. The time now is 03:43 AM. |
