Turbo 350 trans,forward press in park reverse,123gears?
:( I just put a new converter in and replaced the shift shaft seal, to remove the seal i took out the shift linkage in the trans. My problem now is when i start the car it wants to move forward in Park, reverse, neutral, and natrually in all forward gears!! Could i have installed the shift linkage incorrectly. any help would be great, Thanks. :?:
Linkage
Sounds like the shift linkage needs adjustment.
Sounds like the Manual Valve is not hooked up.
X2
If you drop the pan you will probably find the s link from the manual valve to the rooster comb (detent lever) not in place. Rob |
Yes sounds like the clip from the manual linkage to the valve fell off, shaped like a S.
http://img36.imageshack.us/img36/2761/sclip.png |
| All times are GMT -8. The time now is 06:09 AM. |
