TOOTHACHE!!!
How much nitrous can be used on a "pump gas" engine? 200? 300? ?????400 :x :x
THANKS GUYS, LIVELY |
Dennis are you asking how Much NOS can be run on 92 octane fuel or How much NOS can be Run thru a Pump gas (low compression) Motor using High octane Racing Fuel ?
:shock: :shock: Thats my name too!!! :shock: :shock: |
Just keep adding until it blows up, rebuild it and pill it down a hair from where it blew at and you'll be fine. :lol: :lol: :lol: :lol:
92 octane 8)
not a lot...i think Nos phamplet says up to 100hp NOS on 93 octane...then from there they suggest the better gas...
you would still need to back out about 4 degrees of timing to be safe at 100 shot with 93 octane it would also depend where your static compression is...example: 7:1 can probaly handle a little more than a 10:1 static compression motor....and both engines are Pump gas...one is just on the low end while the other is on the higher end. |
I think your wallet will ache more then your tooth!!!! :D :D :D :D :D
Re: TOOTHACHE!!!
THANKS GUYS, LIVELY I have sprayed 150 on 92 pump maybe 8-10 times over a 5yr period On my 11.5:1 406 runs 10:30s on 92 9:70 on 150/92 Pulled the motor down twice over the 5yr’s just to check the bearings And they looked great so back together it went |
| All times are GMT -8. The time now is 12:49 PM. |
