-   -   Anyone Familer with "RACE PUMP" (https://www.racingjunk.com/forums/showthread.php?t=25550)
bjuice 09-01-2009 02:53 PM
Here is the newest mechanical Race pump,,,bolts to stock Block location..
Anyone got any feedback on it...thinking about trying this pump on my New blown street/strip Blown SBC...
http://www.racepumps.com/features.html
johnracer 09-01-2009 03:53 PM
A friend of mine tried one on a 421 small block with a Procharger. Made around 850hp on the dyno with it, but wasn't worth a hoot on the track. He ran it in his 68 Camaro, 5-speed backhalf pro-street type car. It would launch with the front about 3ft high then quit running. He finally went electric and cured it.........
hammertime 09-01-2009 06:36 PM
I've not ran one but was going to try one 3-4 yrs ago and did a little search and found lots of issues and still see people having issues with them, so I'd say, stay away
OneBadGMC 09-01-2009 07:01 PM
Why would you want a pump attached to the engine that would heat soak the fuel???????
suicidebomb 09-02-2009 03:15 AM
Well that's curious onebad, what's your pump attached to?
bjuice 09-02-2009 03:32 AM
the only reason i like the idea of this pump is the manual aspect ( but with No belt) that can pull fuel from a stock location from the rear of the car (stock tank with Sump)......I didn't think the belt drives have this Pull capability does it ?
My plans are to run E-85 Which negates possible heat issues..
Hammer this pump supossedly has evolved over the last few years.....on higher Hp engines the Return line jet Size id very important to making them operate properly..
i dunno...seems like a cool pump if you can get her to work...
Now keep in Mind what i am building....A TRUE STOCK BODIED/INTERIOR 69 CAMARO that will make 1,0000 hp Plus...on BF street/drag radials and looking to run 5.50's or lower and driving to the track. :shock: ......thats my GOAL Anyhow
suicidebomb 09-02-2009 04:20 AM
That pump ain't gonna be enough for ten thousand horsepower. When you reach your goal you'll easily run 5.50s. Just kidding bjuice.
TheYellaBrick 09-02-2009 07:08 AM
:shock: :shock: :shock: :shock:
10,000 HORSE POWER ??
That's more than an Aircraft Carrier !!
I do hope you post a YouTube video of that first run :P :D
bjuice 09-02-2009 09:48 AM
oppps....i meant 1,000....lol :oops:
DRTRCR22 11-29-2009 09:20 PM
A couple of feloow dirt track racers tried them on their 383 and 406 high flow alcohol circle track engines, and had nothing but problems...
They told me you have to run a special high flow fuel regulator that is matched to the pump, allegedly from the same company who makes this pump, in order for it to work right, and the regulator costs more than the pump does, which they are very proud of...
One of the points the ads claim is that this piston pump takes less than 10% power effort than a diaphram pump does, and much higher flow capacity...?
No, a belt does not suck, they only push, and they lose prime real easy, so I stick with an alky high flow diaphram pump with -10an inlet and -8 outlet. A C.V. brand pump is awesome!
