help with bbc
hello everyone and thanks in advance
I'm running a 1972 Chevy nova with mini tub 410 rear gear turbo 400 engine 496 13:7:1 compression hydrolic roller with a victor jr intake with 1 inch spacer holly 950 which flows 1ooo cfm running 11.1 is my best time I will be happy to get to 10.5 . I have the regular water pump will be installing a electric . also just installed evaluators didn't make any diff oh yea just installed 3000 stall speed converter. comp 2 aluminum cylinder heads. with roller rockers. NO Nitrous. any thoughts or Ideas would be appreciated. I think I need to go with a bigger carb ? take the 1 inch spacer out? |
A little more info is it street/strip or strip only? What does it weigh? Rear tire size? Transbrake or footbrake?
What is a comp 2 aluminum cylinder head? :?
corvette motor? :wink:
No ...if it was a corvette motor he would be in the 9's already. You can run 10.50's in a dump truck if it has a corvette motor.
more info
OK its street/strip no cage yet was just a 454 engine bored 60 and stroked
just a foot break car right now cam spec 520/236 intake 540/242 exhaust msd 6al tires m&h 28X12.50 15 street ets latter bars 4 link weight 3200 with me in the car Ill see if I can post some pics soon on launch can get the tires off the ground about 4 in ... don't laugh again thanks in advance. |
more info
pro comp aluminum heads
2.25 intake 1.88 exh 119cc rectangular port |
Re: more info
2.25 intake 1.88 exh 119cc rectangular port Dave |
That cam is nowhere near big enough for a 496, especially one with 13.7 to 1 compression.
Is the 236/ 242 the dur @ .050? :shock: If so with that much compression I'd get it up in the 270- 280 range. |
Put a ''MOPAR'' engine in it. Trash the ''chebbie'' engine :!: :!: :lol: :lol:
| All times are GMT -8. The time now is 03:34 PM. |
