-   -   Powerglide lazy shift (https://www.racingjunk.com/forums/showthread.php?t=25369)
supergass 08-18-2009 05:48 AM
I see another post where someone has a car that hits the rev limiter between shifts. I understand his problem, I have seen the same thing> My powerglide revvs up at the shift enough to actually unload the chassis on a run. I have replace the trans with my spare trans and it works great now. Anybody ever cracked this nut??? Only one guy answered the question saying that it might have a warped valve body. Could the front pump be getting weak?? The fluid isnt burned and the band and clutches look fine. So I am thinking it is a pressure problem. I just need some direction! Thanks
hammertime 08-18-2009 06:08 AM
pressure issue for sure, what valve body ?
supergass 08-18-2009 06:20 AM
Its a Hipster,
hammertime 08-18-2009 07:38 AM
I've had a hipster do the samething before, did you get a chance to check line pressure before taking it out ?
supergass 08-18-2009 08:25 AM
No I didnt but I will do the work, how do I check it? I know about the 1/8 inch pipe plug on the side of the servo cover. Do you just check it at a idle??
jmarksdragster 08-18-2009 11:54 AM
Pressure tap for low and high is the servo cover plug, a brake VB should have at least 200 psi. Check your band adjustment, 3 1/2 to 4 turns out will work.
us7race 08-23-2009 02:07 PM
It can be the pressure relief valve in the valvebody. I had this hsppen as well but with a BTE valvebody. Works fine after cleaning it out and stretching the spring just a little.
