-   -   front end shake (https://www.racingjunk.com/forums/showthread.php?t=25321)
bigmack 08-14-2009 03:27 AM
front end shake
i have a 87 camaro the car drives good but after a wheels up launch car goes into bad front end shake. anybody experience this problem with there car if so what did you do to fix the problem thanks.
bigmack 08-16-2009 09:01 AM
have anyone install steering dampers on there car and did they help.
fla1976 08-16-2009 09:42 AM
Shake
Have you checked front wheel bearings, tie rod ends, center link and ball joints? What about the shocks? Have you tried different wheels and tires? Is the alignment within specs? Has the car always done this or is it a recent problem? Has the frame been damaged? Is the front end tied to the rest of the car with the cage?
Just some things to start with.
bigmack 08-16-2009 10:13 AM
no it recent problem i have check all the front end parts looks good and thigh but it just started doing this, it's got me puzzle man.
MEMRACING62 08-16-2009 10:18 AM
upper & lower control arm bushings?
bigmack 08-16-2009 10:21 AM
only have lower and they'er thigh.
MEMRACING62 08-16-2009 10:24 AM
oops didn't catch year of car :oops: :oops:
