-   -   Dome Pistons - Why (https://www.racingjunk.com/forums/showthread.php?t=25267)
jreiley 08-11-2009 04:00 AM
Dome Pistons - Why
Is there any advantage to using dome style pistons?
chevyfireball 08-11-2009 04:08 AM
More compression?
hammertime 08-11-2009 05:25 AM
More compression ... in the past we've cut the heads a long ways and keep a flatter piston to get better flame travel
oldandtired 08-11-2009 06:05 AM
I love the BIg Chief stuff!!
Dave
ARUSSELL 08-11-2009 06:43 AM
in the high end markets, Pro Stock and Nascar Cup, the cylinder head chambers are getting smaller with shallower valve angles. This alows either a flat top piston or a dished piston to keep the compression up and still get good quench and flame travel.
signsbyesa 08-11-2009 07:28 AM
yep, acomplish the high compression with a flat piston and make
the chamber small, but for those with large chambers can use the
dome to fill the chamber, but flats are a better plan to get high
compression, good luck :wink:
cepx111 08-13-2009 09:45 PM
Re: Dome Pistons - Why
They look cool as hell.
zipper06 08-13-2009 10:12 PM
HaHa, LMAO, i've never seen a dome piston in a running motor.
curtisreed 08-14-2009 04:11 AM
I've seen a few in previously running motors moments later. :oops: :oops:
Curtis
