-   -   383 sbc timing (https://www.racingjunk.com/forums/showthread.php?t=25181)
bigmack 08-04-2009 01:59 PM
383 sbc timing
just want to know what kind of timing you guys running on your sbc just want to know what's working for you guys thanks.
ARUSSELL 08-04-2009 03:06 PM
41 DEG
wmeabates 08-04-2009 03:31 PM
Piston design and spark plug location will have a lot to do with how much spark lead a motor needs.A long time ago I had a 292 ci sbc with big dome pistons and gm strait plug heads,that motor liked 50 to 52 deg.on 260 sunoco pump gas.Now I have a 412 ci sbc flat top pistons 18 deg head that likes 30 to 32 deg. with vp c12.Just some things I've seen with timing.Bill.
bigmack 08-04-2009 03:53 PM
i'm running 36deg but someone told me to try 40 deg, i just thought that was too much. i have a 13 to 1 383 motor with pro action heads and was just woundering if anyone was running that much timing in there small blocks.
Tod74 08-04-2009 03:55 PM
If it has aftermarket heads ask the head manufacturer what they recomend...I've always heard that the chamber design along with the piston shape had a lot to do with how much timing it would like.
FullTimeRacing 08-04-2009 04:36 PM
I have 350 wit brodix T1's 13to1 set at 38*
it runs good so I just leave it alone
bigmack 08-04-2009 05:32 PM
i'm going to take the car out thursday if the weather is good and try 38* and 40* to see if the motor likes it or not. the car have been 11.07 @ 120 with 36* timing in it so i'll let you guys know how it runs.
