-   -   Incase you didn't know, Volkswagen Jetta TDI Cup car specs! (https://www.racingjunk.com/forums/showthread.php?t=25172)
andrew1984 08-03-2009 08:54 PM
http://i25.tinypic.com/34zhauv.jpg
The Jetta TDI Cup car is powered by a 2.0L, 170 HP, four cylinder TDI clean diesel engine mated to a six-speed, double-clutch, automatic DSG transmission.
The car is only slightly modified from stock with Pirelli racing tires, race suspension and brake components, drivers racing safety seat, FIA roll cage and an on-board fire extinguisher system.
Specs:
Engine capacity: 1968cc, 4 valves per cyl., 170HP, 258 ft-lbs tq @ 1900-2500 rpm.
Fuel: Hyperfuels SynDiesel B5 Biofuel
Brakes: Fronts\\ 4-piston fixed-caliper disc brakes, internally ventilated, 356mm (14")
Rears\\ Single-piston floating-caliper disc brake, 255mm (10")
Wheels: 18x8.5" light alloy rims
Tires: Pirelli 245/645-18" slick and rain tires
Curb weight: 1,290kg (2,844 lbs)
Data logging: Memotec AIM data logging system with display
Safety: ABS brakes, 6-point racing safety harness, DefeNder head and neck restraint system, FIA approved roll cage,
FIA homologated fire extinguishing system, recovery hooks front and rear, electric cutout switch, driver side window safety net, Recaro race seat
http://i26.tinypic.com/rsg1p4.jpg
http://www.makehasteracing.com/
http://www.trackmart.ca/
http://www.vw.com/
http://www.scca.com/
http://www.can-alignment.com/
http://www.hotbits.ca/
http://www.hyperfuels.com/
Andrew .Volkswagen. Cordeiro .:R
Email: [email protected]
1975 Volkswagen Scirocco #91 EM
2009 Volkswagen Jetta TDI #26 TDI Cup
outlaw256 08-04-2009 12:36 AM
now thats info i couldnt live without!
Tod74 08-04-2009 01:47 AM
Re: Incase you didn't know, Volkswagen Jetta TDI Cup car spe
Specs:
http://www.vw.com/
I disagree
suicidebomb 08-04-2009 02:35 AM
I think it's cool......when's my test drive?
slowmotion 08-04-2009 02:41 AM
I bet that's a blast to drive. :D
TheYellaBrick 08-04-2009 05:46 AM
Sprint Cup or Tea Cup ? :P :D
Harbone 08-04-2009 07:44 AM
When it breaks down let me know, I make a killing selling those das fuhrer parts! first thing to go will be the glow plugs, you will surely have some form of electrical issue here shortly and last, but not least, then the recalls will start coming in the mail so you will get lots of quality time at the dealership...
FullTimeRacing 08-04-2009 12:48 PM
ONLY gay boys drive VW's!
fla1976 08-04-2009 01:08 PM
All VW's
Monte, I hope you're talking about newer VW's. I think my 73 is exempt. :roll: :oops:
http://img156.imageshack.us/img156/2323/1000168.jpg
FullTimeRacing 08-04-2009 01:22 PM
Re: All VW's
I had a 69 superbettle when I was young.(20)taped up the glass and lights took the hubcaps off and painted everthing black with black out tint on the windows.
ya the new stuff.
it was a cool car
