-   -   Mustang suspension rolling over (https://www.racingjunk.com/forums/showthread.php?t=25171)
repoman28 08-03-2009 07:01 PM
I have a 91 mustang with a sbf a powerglide with coil overs front and rear. I also have adjustable upper and lower control arms. My problem is I stage the car at 2000 rpms and leave the line it leans very hard and scrubs the tire inside and outside of the tire. I also have 28x10.50x15 MT slicks on it. I want to hook up my trans brake so I can leave at 5500. what do I need to do
BillyShope 08-04-2009 04:28 AM
Re: Mustang suspension rolling over
Originally Posted by repoman28
...it leans very hard...
Which way?
...and scrubs the tire....
Which tire?
If you have adjustable coilovers at the FRONT, you'll almost certainly want to use a higher RATE spring at the RIGHT front than at the left to promote more equal rear tire loading during launch. See Page 16.
http://www.racetec.cc/shope
