-   -   valve stem seals (https://www.racingjunk.com/forums/showthread.php?t=25150)
camarotale 08-02-2009 09:44 AM
valve stem seals
why on my new built motor are 2 exhaust valve teflon seals breaking into pieces
OneBadGMC 08-02-2009 10:53 AM
I'm going to guess here...
Either the springs are rubbing on them, or you have a machine shop who can't setup valve heights correctly, and the retainers are smashing them into the guide.
oldandtired 08-03-2009 06:24 AM
x2 Many times the maching shop will cut the guides for a .500 or .531 seal but not reduce the total height of the guide. The valve height will also be reduced when installing new valves. The first time the engine rotates, the retainer smashes the seal.
Dave
