API Bolt together converter
Anyone ever use one of these? What do you all think of them, are they worth the money, thanks
What is your application? I run a Neal Chance bolt together, Its nice if you are going to service it your self or adjust it.
427 small chevy, with a 250 shot on it, 3300lb 4x4 truck heads up drag racing in the mud
just heard good things about them and was trying to get some more input before buying a new one. l have used tci, and coan in the past and had great luck with both but always looking for something new |
Ive got an API bolt together converter,works great!!! DR.
I have a Neal Chance all aluminum converter in my Nova. It reduced the rotating mass by 6 lbs. Sixty foots dropped from 1.14 to 1.06 and ET dropped from 7.06 to 6.84. Cost a lot of money but well worth it. Easy to change the stall by moving shims. Have a spare stator incase I'm not running nitrous. You can clean the thing out yourself if theres a transmission disaster.
Marty Chance is a great guy. Check out the pics of the converter on my RJ profile below. http://www.racingjunk.com/gallery/profile/104786/207987 |
[quote="chevyfireball"]You can clean the thing out yourself if theres a transmission disaster.quote]
And as mentioned, change your stall at any time. Those two features are worth the money. Dave |
If you ever saw one of these up close and apart, you would be amazed. The technology is outstanding
| All times are GMT -8. The time now is 12:39 AM. |
