-   -   carb stumble??? (https://www.racingjunk.com/forums/showthread.php?t=25041)
whitey70ss 07-22-2009 05:03 PM
carb stumble???
I recently changed the carb and intake on my sbc (350 .60 over .510 lift cam 292 duration,edelbrock rpm heads 10.5-1 comp. victor jr intake 750 dp) now when I feather the accelerator to take off (4 spd) it has a slight dead spot and it has a low speed miss?? But as soon as I get past that spot in the accelerator pedal it clears right up. I was planing on going to the track sat. for test and tune, and was wondering what I should be looking for to cure this problem, I already played with the accelerator pump adjustment and checked the floats, and low speed mixers. thanks in advance.
fla1976 07-22-2009 05:56 PM
stumble
Have you read your plugs. Sounds like you need to rejet the carb.
whitey70ss 07-22-2009 06:16 PM
no I have not read the plugs. I havent had it to the track yet or any place I could wind it up and shut it down . any other suggestions.
whitey70ss 07-22-2009 06:17 PM
any idea what size jets I should be running with this combination?? I havent pulled the bowls off to see yet.
fla1976 07-23-2009 01:13 AM
jeys
I'd pull the bowls and see what it has. Then, I'd jump the size a couple and retry it.
whitey70ss 07-23-2009 07:47 AM
the fronts are 66 the rear is 72H does this sound right??
oldandtired 07-23-2009 11:25 AM
What is the model number? That looks too lean for a 750.
4779 came with 75/76 and 8.5 PV
4779-1 came with 70/80 and 8.5 PV
4779-2 came with 70/80 and 6.5 PV
4779-3 came with 70/73 and 6.5 PV
4779-4 came with 70/80 and 6.5 PV
4779-5 came with 70/80 and 6.5 PV (same as the dash 4)
4779-6 came with 71/80 and 6.5 PV
84779 came with 70/73 and 6.5 PV
There are also some other OEM and marine part numbers.
Dave
whitey70ss 07-23-2009 02:11 PM
I drove to the (local)speed shop today and talked to a guy that teaches a hi-po class at the local college. he told me I needed a 45 power valve I had a 65 and told me to jet it 72 in the fronts and 80 in the rears. I put it together and now its raining :cry: it does seem to have better throttle response now :roll: I guess I'll see sat.
OneBadGMC 07-23-2009 04:14 PM
That's a pretty big jet spread. Rear cylinders are going to get more fuel than the front.
Last I heard (haven't run carbs in a long time), 4 jets were the biggest spread you want to do from front to rear.
Maybe someone with better carb knowledge can comment on that.
fla1976 07-23-2009 04:52 PM
Jets
I always tried to run mine square. All four the same. I guess there is no real reason except that it was race only.
