-   -   dart big m chevy block (https://www.racingjunk.com/forums/showthread.php?t=25028)
taps 07-21-2009 12:47 PM
does this block take the 300 taller lifters with solid roller?also will this effect pushrod length or is the cup in the same spot with just a taller body?
hammertime 07-21-2009 07:24 PM
Cup is in the same spot just taller body. A lot of people use them.
hink 07-21-2009 07:52 PM
Re: dart big m chevy block
Use the tall ones
supergass 07-22-2009 04:30 AM
Have your machinist check the clearance on the lifter bores. Both my blocks had to have the lifter bores hone to the proper clearance. It can be catastrophic if the lifters stick . Needs about .0015 to .002
ashbros 07-24-2009 09:21 PM
x 2 supergass
oldandtired 07-25-2009 06:53 AM
Originally Posted by ashbros
x 2 supergass
X3 but make sure the machinest knows what he is doing. Those lifter bore hones cut fast.
Dave
hammertime 07-25-2009 11:39 AM
I'd hope any place you guys took your stuff to would check this .. if not run ! :D
supergass 07-26-2009 04:05 PM
Well you would think so but two different machinist around here didnt check it and one had lifter seize on the dyno and hit valves.
