-   -   How much HP? (https://www.racingjunk.com/forums/showthread.php?t=24974)
kod99 07-18-2009 06:30 AM
How much HP?
I was just wondering how much horsepower a 240" dragster can safely handle and still make good passes? At what HP would it tend to lift the front end or lose traction? Right now it has about 900 HP and runs straight with no traction problems. What kind of changes or equipment would I need to run 1150 HP?
Xrated1 07-18-2009 10:06 AM
Wow Reagan, that didnt last long!! Got "go faster itis" already?
hammertime 07-18-2009 10:45 AM
Depends on how you go about the 1150 hp with 900 and spray just turn the spray on out further, if with motor you may need to make some changes to bars and take some hit out of it so it dont carry the front wheel out.
The issue you will find with a very fast car is your limited to the tracks you run because they need to be great and not just ok tracks.
kod99 07-18-2009 10:50 AM
No, no. I don't want to go faster right now as the car seems to be very consistant. It's just that I have to tear the engine down this winter (so I can find out what's in it) and I'm trying to decide what to do at that time.
kod99 07-18-2009 10:54 AM
I don't want to run any NOS, just motor. I never thought about the tracks. I suppose the launch would have to be much softer on marginal tracks. What would a guy have to do to the bars?
kod99 07-18-2009 10:57 AM
Rod, are you heading for Edmonton next weekend?
hammertime 07-18-2009 04:26 PM
You would have to 1. take some hit away from it move the IC out a little bit but not not far, 2. Non aggressive converter 3. Digital 7 ignition box to take timing out at the hit. Tracks usually dont like more then 1000 on 100 degree day around here.
Xrated1 07-18-2009 07:54 PM
Yup probly just Sunday though
quick8dragster07 07-24-2009 06:47 PM
I'm running 1540 right now in my 260" bos, and seems to be alright! I also have a slip tube 240" with 800hp for bracketing. They both like to leave pretty hard but haven't had to much lip out of them on hooking up. I never had an adjustable suspension in the back though, I always heard it made up for poorly built cars! :lol:
hammertime 07-24-2009 07:48 PM
or a bad track ;) or making stopping easy :wink:
