502 block max horsepower?
I have a 540 built by shafiroff that came in a car I bought. Just freshened it with JE pistons, bearings etc. Has eagle 4340 crank, h beam rods w/ L19 bolts. I am running a fogger on it and was wondering if anyone had any suggestions on max horsepower this block will handle. It's about 15:1 compression and I have already sprayed 150 shot with no problems. Do I dare try a little more squeeze? If so any tips on nos/ fuel jetting and fuel press.
Re: 502 block max horsepower?
Don't push a factory 502 block much past 850hp. I ran a 548 with 868hp no problems, but was always a little nervous to go anymore.
I don't know about the cylinder wall thickness of the 502 blocks, but I ran a 427 tall deck truck block at .100 over bore, to 1200 dyno'd crank HP.
It gave up the ghost when I banged the blower from too much timing and not enough fuel. Put an "H" crack in the side of #5 cylinder. |
Is it bowtie block?
15:1 COMPRESSION AND ONLY GIVING HIM 600-700 HP?!?!?!???
Yeah, it should be around 850 hp or so. It ran 8.50 in my 2000lb altered at 5800 ft in denver. 8.11@163 with a 150 shot. At lower altitude you can figure .6 sec faster. Wish I would have went back to Kansas and raced it before I got rid of the car. It went 8.000 one time at great bend before I had the heads ported. Ported the heads before I ever ran at denver but it seems to have picked up .5 sec. or so. My buddy from there runs 7.70's in kansas and 8.30's when he comes to denver. May never get in the 7's now with a heavy old chevelle! Anyways, it seems I may not want to hit it with a 300 shot. I'd rather not blow it up and crash the car. Heads flowed right under 400 cfm after the port job, 310 cfm before! Just some junk old 305cc brodix -2's. Block is not a bowtie. Wonder why Shafiroff ever put these together without a dart block? Has anyone seen any actual problems with these or is everyone just worried like I am? Sounds like the cylinder walls are a bit thin is the problem.
Mine block was fine, but it did run warmer than I liked.
My motor is a 509ci. The motor made 800hp and i run a 300 shot on it. Ive had no problems with it at all.
| All times are GMT -8. The time now is 11:49 AM. |
