Yellow Plugs after nitrous run?
I have a delema with the nitrous system on a vehicle the setup is as follows:
sbc 350 .030 over forged manley blower pistons 8:1 comp. race prepped rods, crank and block bowl blended heads TBI setup 1 annular discharge nozzle with .065N .053F jets run 10lbs. fuel and 9-950lbs. nitrous psi. After a run the plugs have a yellowish tint to them, I don't see any other signs on the plugs as being to rich, or lean cond. the plugs do show a rich idle but thats from the cam I'm using the computer doesn't like it at Idle. Anybody ever run into this with having yellow tint on porcelain after a run? and it only does it on nitrous? Thanks, NorthernPeaks[/img] |
Just a little on the lean side, that is where I run my N/A engines
What brand of plug you running?
The yellow tint is from sulfur dioxide. It is a chemical put in "RACE" grade NOS. That is what seperates it from the medical grade.
TS1955 |
yellowing
master builder is correct
DO YOU USE LEADED FUEL?
TS1955 Yeah, that stuff is to keep idiots from huffing it. Didn't phase my neighbor though, came by when I was taking my bottle our for a refill, he asked is it empy? I said yeah, he grabs it takes 2 big hits and said no it's not :shock: I just shook my head. |
| All times are GMT -8. The time now is 08:14 PM. |
