-   -   Oil temp!!! (https://www.racingjunk.com/forums/showthread.php?t=24913)
ajk 07-12-2009 01:15 PM
Oil temp!!!
Built a new 421 sbc. 1/2 hardblocked. Water temp is good but oil temp seems a little hot around 250 to 260 degrees. Is this a result of the hardblock? This is a street motor and i am about to switch to synthetic oil does anyone have a take on this? I am hoping that this is normal. Thanks for any help or input.
russ67chevelle 07-12-2009 08:04 PM
ive heard guys said that with a half filled block oil temps rise,so naturally an oil cooler would be an easy soulution,good luck should be ok :)
oldandtired 07-13-2009 06:08 AM
x2 on oil cooler.
The oil is pulling the heat away from the bottom of the block that the water was doing before.
Dave
