-   -   PG Hitting Rev Limiter L to H shift (https://www.racingjunk.com/forums/showthread.php?t=24901)
topfuelryan 07-11-2009 08:48 PM
My FED started to stumble for a split second when I would shift from low to high. We think it may have been hitting the rev limiter but never saw the tack jump up (shift at 5600 to 5800, rev limiter at 6200) at the shift. I swapped out trans and sure enought the problem went away.
Do you guys thing it is in the trans, or the torque converter? Anyone else ever have this problem?
kbartley 07-12-2009 04:56 AM
HMMMMM?
Need more info. Like how fresh is the trans/convertor that you took out? So what you are saying is it slipped going into high gear? Sounds like the band is out of adjustment. Do you have a T-Brake?
Kris
itsabird 07-12-2009 05:23 AM
just to be clear, are you saying that you are shifting at 5800, and you have a 6200 high side chip installed?
topfuelryan 07-12-2009 07:50 PM
The trans has around 500 runs on it. I adjust the band every other weekend of racing or so. I don't believe it is because the band is out of adjustment.
I usually shift at 5800. Yes the rev limiter has a 6200 pill in it. I shifted at 5600 a few times and 5200 a few times and it still acts like it is hitting the rev limiter for a split second.
itsabird 07-13-2009 03:37 AM
i would try a bigger high side chip, i have seen chips say they are one thing and be another, next you are shifting fairly close to your high side chip, unless you are useing an automatic shifter, it could easely be crawling past your intended shift rpm. jmo
hammertime 07-13-2009 05:57 AM
If you would of moved that highside up the issue would be gone I am thinking.
Just because you tell it to shift @ 5800 doesnt mean it is.
rob41willys 07-13-2009 08:14 AM
Sounds like the high gear clutch pack might be slipping?
topfuelryan 07-14-2009 12:29 AM
it is not the high side chip, pulled it for a run and it still did it. It is something in the tranny. The high side chip is fine with my backup trans.
topfuelryan 07-14-2009 12:31 AM
hey rob, I think I have raced you at Pacific before. Have you ran the friday night Goodguys the last four or five years?
shawnp 07-14-2009 03:14 PM
If you are using the same converter when you put in the back up trans and have pulled the high side chip, then you have narrowed it down to the trans. I have seen guys whose transmissions rev up on the shift. We have found that the valve body is warped or worn. It does sound like it is time to freshen that bad boy up.
